Had been looking for a phone holder mounting solution that I liked for some time...and was considering working off the accessories that are available to bolt into the center dash to pull something together, but then I saw
this post over on
@MountaineerTom 's page and decided to go this route instead. I thought I might actually just fab one up myself, but then realized how cheap the CB shelves are and made the decision that it wasn't worth the effort involved.
The CB shelf attaches to the side of the dash using the 2 screws that are already there from the factory to hold that dash panel in place. There may be a couple different brands of this shelf and I think they are likely all nearly identical - I ended up with one from
V8 God on Amazon that is powder coated and has 2 sets of holes on the side so you can choose which height you want for the shelf. I went with the slightly higher mounting position simply because the previous owner put the trailer brake control box on the dash in this location so I had to get the shelf above it.
If you look closely, you can also see I used a couple of felt chair feet pads on the backside of the CB shelf so it makes more consistent contact with the upper portion of the dash that is slightly angled away from vertical - this helps minimize any vibration of the entire setup while driving.
The shelf has some slots already cut into it intended for the bolts that would allow you to attach your CB - these slots were almost wide enough to allow the threaded stud of a RAM ball through, but not quite. I ended up drilling out a couple of spots in 2 of the slots just a little wider and attached 2 RAM balls. One is currently used for the phone holder and the other is not visible in the below image, but is positioned so I could easily attach a GoPro down the line.
I have been using the
RAM X Grip on my motorcycle and it has worked well, but since I purchased it a few years ago RAM has since come out with the
Quick Grip holder and I thought I would give it a try. While both styles are rock solid, I like the ability to load the phone into the Quick Grip with one hand.
I like this phone mounting location as well - it puts the phone right up against the A pillar so it doesn't block any line of sight through the windshield. And as you can see below, a standard length cell phone charging cable reaches easily from the factory power outlet in the center dash over to the phone.
Ballpark costs (although I had some of the RAM stuff already on hand):
CB Shelf - $16
1" RAM balls - $10/ea
RAM arm - $10
RAM Quick Grip holder - $26
