LockNLube coupler
LittleTankTJ
TJ Euthanist
Lifetime Supporting Member
Where the redwoods are
I know I mentioned it forever ago in another thread. This coupler saves many headaches from the basic grease guns you can buy. This coupler spring loads onto your zerk and stays on until you release it. It's pretty cheap but super useful.
I've found the latest cheap store brand grease guns to hold too tight or not tight enough and the adjustment doesn't help much.
Just the coupler:
https://www.amazon.com/dp/B00H7LPKKU/?tag=wranglerorg-20
Reactions: BlueC
Got one and it is the best grease fitting I’ve ever used. It’s a bit bulky and tough to get in tight spots, but absolutely the best.
Got one here too. But just as @TJ Jim says, its a bit bulky for some tight spots.
Same here, I keep two guns. One was a slim needle on it for those hard to reach places.
Reactions: TJ Jim
I need that 👆 because switching threaded tips is a time suck.
EDIT: what if I add a zerk to my current needle, shouldn't it work the same w the LockNlube coupler? I'll have to see if I have the proper thread sized zerk to test it.
You could probably do it. Not sure if it will end up any cheaper. But if you have it all laying around, worth a try
