I read Chris use the term "snubber". So it must be correct. I keep calling them rubber bumpers.
I'm just wondering. Rather than cutting up a bunch of snubbers (or hockey pucks) to sandwich them into a longer version. Does anyone know of another rubber stop like that that would work? Like maybe even something from a different model vehicle or application?
Just wondering if there's a simpler solution? I'm having to stack up 3-4+ cut up snubbers to get the distance I need to hit the tire firmly. I'm using the Smittybuilt spare tire adapter. Which adds another 2-3 inches of distance - from the spare tire to the tailgate. And a stock JK wheel and tire (255/70r17?) that adds distance as well. I haven't measured but I'm guessing you'd need a 4 and 5 incher to reach the spare.
And since you can't really see them. It wouldn't matter what exact shape they were. They'd need to just be able to be bolted on and be at least 4 to 5 inches tall. But a similar height would be fine as you could grind off some of the length on either end. Again, no one sees them. And it seems like one piece of metal reinforced rubber would be better than a stack of so many sections of a stock one.
EDIT - Scroll down and see the solution. Rubber mallet heads from HArbor Freight. They cost about $2.99. And are just about the right length. They can be cut too. To make custom lengths. Genius.
