Does anyone know what the factory bolt size is? I want to buy some longer bolts before pulling them off.
Just replaced mine this weekend - not sure if they're all the same but on my 2000 sport:
M6x1.0
I ended up buying a few 50mm and a few 60mm so that I could have about 10mm of thread 'insurance' - which is okay because the door is thicker than 10mm!
Good luck
Cool, thanks man!!
No problem - one helpful thing to add is that the stock bolt length was about 15mm - so add whatever your spacer thickeness is to that and that will be the length of your new bolt. I rounded up to the nearest 5mm just for good measure.
One last question. What size is the stock bolt head. I squeezed a 10mm in there and it seemed small. It also seems like a deep socket is needed. Thanks
Mine were actually all T35 Torx head
You just installed the hinges, without the rest of the tailgate reinforcement?This arrangement lasted 18 years with hardly any tailgate sag until I installed the Exogate hinges last month.
Not sure about him, but I (bought) and installed just the Heavy Duty Hinges only on mine.You just installed the hinges, without the rest of the tailgate reinforcement?
So you need like a 5.5 inch bolt maybe? I went to Ace Hardware. But mine has a whole room of fasteners. Mcmaster carr would be my only suggestion. But call or email them. Their salesmen are engineers. And super knowledgeable. And super nice. Just tell them what threads and how long. Im sure they could hook you up. I've purchased really weird stuff from them. If they don't have nobody does. You can try their website. But calling or emailing is often better.Sorry to revive an old thread but has anyone ever had trouble finding bolts long enough becuase the tire/carrier were too far away from the body. Longest bolts I could find anywhere were 110mm. Only solution I could think of so far was a connector + threaded rod or a standoff.
Have the Hyline bumper with tire carrier installed.
My ace didn’t have much of a selection and Home Depot only had the 110mm. Even on McMaster the longest I could find was 120mm. But I didn’t try calling. I appreciate it I will give them a call tomorrowSo you need like a 5.5 inch bolt maybe? I went to Ace Hardware. But mine has a whole room of fasteners. Mcmaster carr would be my only suggestion. But call or email them. Their salesmen are engineers. And super knowledgeable. And super nice. Just tell them what threads and how long. Im sure they could hook you up. I've purchased really weird stuff from them. If they don't have nobody does. You can try their website. But calling or emailing is often better.
