So I’m trying to get my cruise functional. I’ve vacuum tested everything and no issues, heater controls switch vents as well. Replaced the brake switch, checked all the servo wires to the brake switch and pcm with an ohm meter and everything is good. Haven’t pulled the airbag yet to look at the steering wheel buttons, but when I turn the key on and when I do a dash diag test the cruise light does not illuminate and I tried swapping the bulb to no avail. I tried searching but couldn’t find any real help. Any ideas on what to check next before throwing parts at it? I have no codes, no lights on the dash, and everything else works including the horn.
