Im sure this request is asked a lot, but here it goes. I am looking for front and rear Dana 44 housings lockers would be nice. Ultimately gonna put 4:10 gears in them. Im having a very hard time finding anything remotely acceptable. If anyone can lead me in a direction it would be greatly appriciated.
Thanks
Tony
I'm ~30min drive from the Toledo/MI border a few miles south of DTW airport. I have a few things on the list. . . .
-non-Rubicon TJ Dana 44 rear w/ 3.73, Trac-Lok, drum brakes from a '98 Sport. The housing was sandblasted and rattle-canned black earlier this month. The Trac-Lok is roached, haven't taken it apart yet
- TJ Rubicon OEM 4.10 gears, donor vehicle (avatar) has 168k. I haven't received my LJ from the shop, or the take-out parts to assess wear & condition
- TJ Rubicon front and rear lockers. Both worked when removed, both have 168k miles. The rear actuator was replaced with a new Crown unit a couple years ago at ~160-161k miles. Gear swap is in process and I haven't received these parts back yet.
-TJ Rubicon front and rear locker pumps, both working. One OEM, the other is aftermarket replaced at 160k miles
-wiring harness from locker pumps to the axles. The switch is still in the Jeep, and I did cut the harness at the transfer case
Also have access to (FIL) a front Eaton TruTrac for standard rotation Dana 44 w/ 3.92-5.38
. . . and I do have the matching front Dana 30 w/ 3.73s, blasted and rattle-canned housing
. . . and also a rebuilt HP Dana 30 w/ 4.88s, and rebuilt TJ Dana 44 rear w/ 4.88s and ARB
