Tore down the double cardan joint on my front driveshaft to rebuild it. Unfortunately it looks like I need a new driveshaft…
The shaft is badly worn. You can easily feel all of the visible marks. The centering yoke has a small amount of play in the ball and socket joint. The retaining ring fell out when I removed the yoke.
The Jeep is a 1997 4cyl 5 speed and it’s had lunchbox lockers for an unknown amount of time. I bought it a few months ago. It still has the Dana 30 front, with 4.88s.
What are my best options to replace this driveshaft?
If I try to swap in a used driveshaft, will the balancing be different?
Thanks in advance for the help. This was a real bummer to discover after finally getting the old u-joints out.
