Taken from an AutoBlog article:
Mopar is unveiling Jeep Performance Parts axles as the latest off-road accessory to the Jeep Wrangler, which itself won the "4x4/SUV of the Year" honors at SEMA for the ninth consecutive year. The show opens Tuesday and continues through Friday at the Las Vegas Convention Center.
Mopar teamed with longtime partner and auto supplier Dana to develop the axles, which are co-branded under the name JPP Ultimate Dana 44 AdvanTEK. They're installed on a Nacho Wrangler concept at Mopar's 15,345-square-foot display.
The high-strength axles are built in the U.S. and feature gear technology that reduces gear set packaging, with added strength and overall rigidity for the trail. The high-clearance carrier design adds an extra half-inch of ground clearance, with an expanded range of gear ratios (4.56, 4.88, 5.13 and 5.38) to accommodate for more tire sizes. Chromoly axle shafts, thicker quarter-inch steel bracket mounts, 9.5-millimeter tubes and upgraded U-joints also add durability, while a nodular iron differential cover adds rugged looks, and its ribbing adds strength and rigidity.
The direct bolt-in assembly allows for use of OEM components and includes electronic differential lockers already installed.
The axles will be available for purchase starting next month.
