Low engine temp
JakeHitman
Washington
On my Gauge it shows the temp at the 2 of 210. And my heater seems a bit cool would that have to do with the Thermostat.
Either your thermostat is stuck open or someone cluelessly installed the wrong temperature thermostat.
Install a fresh 195 degree thermostat like from Stant (SuperStat from Stant would be a good choice) or similar high quality thermostat.
Make sure the fresh thermostat you install is NOT a "failsafe" type of thermostat. That type of thermostat tends to get stuck in the open position.
Reactions: Zorba
I just put a 195 thermosta from advanced auto. My gauge was at the same temp as yours and still is with the new one. My heat still sucks. Maybe I sould try a different brand stat?
I am right now looking for the Stant SuperStat that fits my 97 2.5.
My 99' 2.5 gauge needle basically sits on the # 2 (about 195 on the reader) pretty much all the time in this climate with great heat so I would probably consider a more aggressive core flush.
