2006 LJ Dana 44
Just replaced the pinion seal and refilled, but I feel like not enough went in. Using here, a Haynes, and a few other spots I know the 44 should hold 2qts oil, however using the often wrong measurements on the jug it started coming out the weep hole at about 1.5qts. My pinion is canted slightly up to compensate for the lift(I'm not a human protractor but maybe 5degrees), which I'm thinking didn't help.
Any way to get that last .5 qt in or do you guys think I'll be good?
As a somewhat bench mark the Dana 30 took about the right amount
