Anybody got any advice on greasing the center U Joints? At this point I am having to drop the front drive shaft. I am currently PB Blasting the skid plate in an attempt to be able to routinely remove. Any better ideas?
If there are no grease points then they you can't grease em unless you take it apart. Might as well swap in new ones. Heck just rebuild the shaft and be done with it for another 100k+.
I wish you luck on the skid removal. I got the spinning-forever bolts and had to cut em.
