Last night after work, I was using an M18 angle grinder with a wire brush to prepare some columns for the shop mezzanine I'm building for primer. It was about 100°F outside. I was using 6Ahr and 8Ahr High Output batteries. The columns are 3-1/2" square tubing about 9' long. I couldn't even complete two sides of a column before the batteries (it happened with three different batteries) went into over-temp mode and quit working. That was probably 5 minutes, maybe 10 minutes of running. If you've run grinders in high ambient temps, what has your experience been? Do you have to rotate batteries and cool them down?
Thanks,
sab
Thanks,
sab
