So, on a modern engine, like my 2014 Yukon, which I run a full synthetic, I can go longer without changing oil than on my TJ? Correct?I change the oil on my 2005 TJ every 3000 miles and rotate tires every 6000. This makes it easier to keep track of tire rotation by doing every other oil change.
On my 2012 Kia Sportage that's using synthetic I go 7500 miles, but that is a modern engine.
NO!!! Synthetic and conventional motor oils absorb dirt, combustion byproducts, and naturally occurring acids at exactly the same rates and because of that need the same change intervals. Companies like Amsoil are scamming people like crazy with such claims that if adhered to is just harmful to engines.So, on a modern engine, like my 2014 Yukon, which I run a full synthetic, I can go longer without changing oil than on my TJ? Correct?
I've become kind of an oil filter guy over the years, K&N is just one of the bunch of overpriced filters that is no better than anything else. My three go-to filters are the AC-Delco Duraguard, Purolator PureOne, and, gasp yes, the Fram Tough Guard. Fram's Tough Guard is actually a much better oil filter than some of the high priced oil filters.
My oil change interval is every 5k miles. To me, every 3k miles is excessive and just something that was started by Jiffylube who used that recommendation to get people to change their oil more often to make more $$$.
You are correct, you have been brainwashed.@Jerry Bransford do you think advances in oil technology plays a part in this?
I've always changed every 3,000 miles, maybe I am brainwashed.
Synthetic oils may technically last longer if there's no dirt, combustion byproducts, or acids in them but they get just as dirty just as fast.
Interesting piece of trivia... back in the 50's when I was a young boy, I distinctly remember magazine ads by both Volvo and Mercedes Benz. Of course those were the days before synthetic motor oils were sold by the auto parts stores. Those ads were based on customers who had over one million miles on their odometers with the same engines the factory installed. On conventional single-weight motor oils like 30 weight. There were no multi-weight oils sold in the auto stores back then.:campeon:
OK, I will shift to 5,000 miles and if my engine explodes I will send you the bill
Their goal is to create a sense of wonder about Amsoil oil... as in 'wow their oil last 20,000 miles' so it must be superb stuff. It's no better than any other good quality motor oil, they just are very effective at marketing it as a "wonder oil".What benefit would there be for Amsoil saying full synthetics don't need to be changed as often conventional oils? They would sell less oil (though a full synthetic is higher price, it is not proportionally higher relative to the change frequency/price of conventional oil).
Gotcha! I use Castrol. My dad said don't use Pennzoil, it gums up engines. What's your take on good motor oil?Their goal is to create a sense of wonder about Amsoil oil... as in 'wow their oil last 20,000 miles' so it must be superb stuff. It's no better than any other good quality motor oil, they just are very effective at marketing it as a "wonder oil".
Pennzoil has been fine for many years since they switched away from their old base stock to their reformulated PureBase back in 1998. That stopped the sludge buildup that older Pennzoil oils earned a reputation for that your dad (and I) remembers. It has been a good choice since that change in 1998.Gotcha! I use Castrol. My dad said don't use Pennzoil, it gums up engines. What's your take on good motor oil?
