I have a question I hope you can help me with, I had a crank no start problem so I started changing parts, and of course the problem has gotten worse, I have no crank, no back up lights, no odbII PORT, no rear lights , the gages needles don’t move, the battery shows 13.5 volts,I cannot jump the starter at the fuse box. The starter works on the bench, headlights work but DONT dim when I turn the key, the ignition switch is brand new, so I need some guidance here
