Hey All,
This is my first entry on this forum and I am pumped. I got my 98' TJ a few weeks ago and I couldn't be happier, however, I've run into a few speed bumps and I suspect something is up with my transmission (manual 5 speed)
First, I live in Wisconsin which, at the moment, reaches temps of about 0-5 degrees most mornings. When I start my jeep then go to shift, the shifter is usually VERY stiff. Usually only for 1st, 2nd, and reverse gear. After it warms up a bit, it improves. Second thing I've noticed is that, while I am sitting stationary, I can shift through the gears like butter, no issues at all. Then, when I am moving and I shift from 1st to 2nd (for example) it's noticeably more difficult. It has grinded once and sometimes it won't be in gear when I thought it was.
At first I thought it must be transmission oil that's too heavy for the cold weather. However, I am beginning to wonder if it's a bad clutch. The Jeep only has 33K miles on it so I'm leaning towards the oil but what do you guys think?
Thanks!
Thanks!
