At 4.25” front and 3.75” rear, could I run 35’s with the MCE’s?
“That’s a negative ghost rider, the wheel well is full.”On my particular setup but with MCEs, 35s would start to dig into the rear fender wall at full flex, full steering lock.
Currently, mine is bumped to keep the tires just out of the front fender lip at full flex. There is just enough room to fit my fingers in between the tire and rear wall at full lock, full flex.
I ran 35’s on 4” SL and no BL with them.At 4.25” front and 3.75” rear, could I run 35’s with the MCE’s?
I went full LED WITH A 2.5” grommeted light in the grill and a 3/4” grommeted in the hole where the original wires came through the fender wellCycle at the right speed and to work with the stock incandescent bulbs as well. I already have the JK turn signals in my grill, but tucked the old side marker lights up and in the engine, would like to dig them back out and mount in my aluminum inner fenders.
Love the carbon fiber matched headlight bezel!I went full LED WITH A 2.5” grommeted light in the grill and a 3/4” grommeted in the hole where the original wires came through the fender wellView attachment 134770View attachment 134771
Not the 10.75" that both you and I have...What kinds of shock travel?
As I wait for the elevator...Not the 10.75" that both you and I have...
Seems like a great option indeed. How is the color fade on these being that they're made of ABS?
Sorry for the oblique Top Gun semi-quote. Just mean to say your answer is a negative, it won’t work.Your 33s hit both the upper lip and the rear wall at the same time?
I have 3” SL up front, 2.5” SL rear and a 1.25”BL. What do you think? Same scenario? Have to increase bump and lose up travel?I ran 35’s on 4” SL and no BL with them.
5-1/4” up with the old springs and Fox IFP’s and almost 5” down.What kinds of shock travel?
Yes with the stock fenders for sureI have 3” SL up front, 2.5” SL rear and a 1.25”BL. What do you think? Same scenario? Have to increase bump and lose up travel?
I wonder how much more bumpstop I would need to keep it out of the rear wheel well at full stuff full steering lock?
Have you had issues on the trail due to your 33’s that would have been solved with 35’s, given all else equal?
I'm asking for my scenario with MCE's, not stock. Well, let me think this through. MCE's use the stock fender, but you cut it, right? Get rid of the pinch weld? Is that where you get your up, plus a little flex from the MCE plastic?Yes with the stock fenders for sure
