This unexpected Ohio heat wave is getting to me. It's a sweltering 68 deg right now.Your dry sense of humor detector is FUBAR today. You already said it was raw steel and you painted it black.
Apparently.This unexpected Ohio heat wave is getting to me. It's a sweltering 68 deg right now.
Going to match the fairlead.It looks a little off but only because is matte unlike hooks and fairlead.
Took it out for an extended drive this morning. Just a hint of a vibe above 70, so I think I'll work on dialing that out this week. PSC is next up.Congrats on the first drive.
Can you show how they modded the axle mount. As soon as I can put power to my welder and plasma cutter this week I need to do the same.Ok, with having to rebuild the rear end this past week I am running out of time to do some of the work I need to do before Moab in 2 weeks. So, while Highlift Off-road was doing my front axle seals under warranty, I asked them to do the PSC. They agreed and had to call Blaine to confirm some things about the install because I have an RJ44 which requires some mods to Blaine's kit.
While I have done all of my work the past 2 years since 4WP fucked up my stock Rubi lockers during a regear, I just don't have the time to do everything. I out my trust in Highlift and it appears they did an outstanding job with the install. They modified the axle side brackets for the larger RJ axle and even dabbed a bracket to install the reservoir as close as possible with a very short feed line to the pump. See pics.
As I picked up and drove away, I thought to myself, "this rig has never driven this nicely." The steering feels tight, smooth, and has no movement when hitting imperfections in the road. I was impressed. He'll, I even have zero bump steer now. But,...
...precession is back. Hit a bump on the highway at 65mph and, boom, prewobble shimmy. Then a few miles later, boom again, but had to pull over and stop this time. Fuck! So, I took the side roads home at no more than 50mph. Didn't do it at all again. I'm baffled as it has never driven so refined. It feels like my wife's Genesis G80.
Don't even know where to start now. I haven't had a shimmy or wobble since last Fall. FML. Good thing I'm trailering it to Moab. View attachment 241788View attachment 241789View attachment 241790View attachment 241791View attachment 241792
Make sure the lock tabs on the cooler mount are between the back of the V bar and the front of the mount. Basically once you put the tab in, the mount will not fall off with no other hardware installed.Ok, with having to rebuild the rear end this past week I am running out of time to do some of the work I need to do before Moab in 2 weeks. So, while Highlift Off-road was doing my front axle seals under warranty, I asked them to do the PSC. They agreed and had to call Blaine to confirm some things about the install because I have an RJ44 which requires some mods to Blaine's kit.
That is not my cooler is it?
I gave them the one I got from you. It looks like they cut the fins on the back.That is not my cooler is it?
Thanks, looks like what I was planning.
Why did they hack off the lower half of the outer cover plate?
Where is the stainless steel mount that goes with it?I gave them the one I got from you. It looks like they cut the fins on the back.
I didn't know. I picked it up to now but in the dark.Why did they hack off the lower half of the outer cover plate?
Don't know that either. Apparently, going back there tomorrow to find out.Where is the stainless steel mount that goes with it?
This is what it looks like from the back side.Don't know that either. Apparently, going back there tomorrow to find out.
