Measure Once, Cut Twice: A Story of Excitement and Impatience
It is like the difference between an auto and a manual. I can make them both the same capable off road. You won't appreciate how much more it takes to make the manual as capable.
Get it up as high as you can. Stick some expensive coilovers on it and the biggest tires you can get hold of. That's what it looked like to me in Bronco land.
Used a 2x4 and a jack to bend the tub back into half-ass shape for the corner armor install. 2x4 works prety good for paintless dent manipulation. I was able to jack up the rear by the corner and bend the tub and crossmember mount back up. Then i used the 2x4 to work the panel as flat as possible. I was able to get the buckle out of the side fairly well. We'll see how the armor fits once i get it.
