My wife knows pretty much all of it, but it’s best to not remind herI get encouraged to buy shit, she works from home. She hauls it inside. Works well.
If it ain’t broke don’t fix it!Nope. My strategy has always been misdirection via another fight. Well, maybe not necessarily a strategy, but more of a proclivity.
If you need more than a hitch pin and a soft shackle, you might need to tug from someplace else.Just got email confirmation that my Savvy receiver bumper shipped. @mrblaine What recovery point do you use and recommend in the receiver?
That's what I thought. But I asked because I remember seeing Nick's Jeep in Moab with something sticking out of his receiver; and I thought to myself, "That has to drag." So, it's either something he added after your work or my memory is shot to shit. Thanks for clarifying.If you need more than a hitch pin and a soft shackle, you might need to tug from someplace else.
i can move the shanks by hand on the one on my basement floor............ and i can move my 1T TRE's on the rig now by hand a bit.On a Currie Correctlink, how easy should you be able to roll/twist/rotate the tie-rod or drag link by hand?
Edit: I'm not referring to adjusting the collars, rather what would be considered acceptable TRE movement In this system?
You can move the pins by hand after they have worn in a bit. They should rotate easily but no excessive play. No popping up and down on the ball. The drag link will only move a small amount since the body is slotted.On a Currie Correctlink, how easy should you be able to roll/twist/rotate the tie-rod or drag link by hand?
Is this too much?You can move the pins by hand after they have worn in a bit. They should rotate easily but no excessive play. No popping up and down on the ball. The drag link will only move a small amount since the body is slotted.
+1 similar to mine as welllooks bout same amount of motion as mine.
Drag link or stub axle shaft?looks bout same amount of motion as mine.
DL/TR...............IDK bout the hub looks bit sloppy.Drag link or stub axle shaft?
Drag link, sorry.Drag link or stub axle shaft?
