Measure Once, Cut Twice: A Story of Excitement and Impatience
taylormade73
taylormade73
No More Shimmies? 🤞
Miami Valley
last time i looked i thought a new TDK frame was in the 2600$ ballpark and you could then add custom mounts above that if desired.
was a southern frame in IN> but it's gone. a few in columbus that claim to be southern and rust free but you can see some rust so IDK who he's trying to fool there. 1200$.
if i see anything good local/in state or close......i'll post it your way.
Cool. Thank you.
taylormade73
taylormade73
No More Shimmies? 🤞
Miami Valley
My nephew found this when he pulled the head back off. @Irun is so right to replace these when you have the head off.
Apparition
TJFest June Edition 2023
Twin Cities, MN
I bought the smaller Neiko set and am curious how it will hold up. Hopefully, better than the HF junk that keeps breaking!
I’ve been running that smaller set for a couple years, no issues. But, I haven’t put them on my impact either.
After seeing Jason’s set I wish I had a T70 just because.
taylormade73
taylormade73
No More Shimmies? 🤞
Miami Valley
Mopar motor mounts and RC lift blocks got here Friday. Today I replaced the MORE mml.
Passenger side stud was too close to the bracket-to-block bolt. I couldn’t get a socket on it, so I had to improvise.
Crows foot worked slowly, but nicely.
All finished.
I will say that it reduced the idle vibes significantly but not completely. One unexpected benefit though was the very slight harmonic/drive train vibe that came on around 67mph is completely gone. I took it up to 75-80mph and zero vibes. I call that a win.
starkey480
Tuned springs club
San Tan Valley, AZ
All finished. View attachment 345323
Just to double check, did you clearance the motor and frame brackets on the passenger side?
Mike_H
Off-Camber is scary
I've been thinking about doing this too...I have the same MORE bombproof mounts that you had installed.
Viking Jeeper
2A Supporter
Jacksonville FL
I had the same problem getting a wrench on one nut on passenger side with new Mopar motor mounts and Savvy lift blocks. I did have a clunk start a few weeks after I installed and found one of the studs (also passenger side) was hitting the block. Had to do some trimming.
