Ok so I messed up. I was putting together my RGA front axle shafts and I forgot to put the damn snap rings on the u joint cross before I hammered it together.
So I pressed the u joint apart so I could install the snap rings and I pressed one cap through the yoke and now I’m stuck with this.
I’ve tried several times in various ways to get it out or press/hammer it through backwards so I can start over but no dice. Being that I spent a pretty penny on these and waited a long time to get them, I’d appreciate any advice so I don’t totally screw this up even more than I already have.
So far I’ve put the other cap on and tried to hammer and press it back through and I got it some of the way through and noticed a metal sliver so I stopped and reassessed my dumbassery.
FWIW after I screwed this side up the driver side axle shafts went together great. It’s amazing what you can do when you follow the correct procedure.
