2004 Jeep TJ with NV3500 5 speed manual trans.. I changed my transmission fluid recently and found metallic whiskers attached to the magnetic drain plug. I know this is normal but is there any way to gauge if the amount is too much or about average?
If it us metal 'dust' and no chips or slivers then it is likley ok. But too much of any metal debris is a bad thing. How long since its last fluid change?
IF it looks like a cats hair ball then that's too much.... Just joking...
This past January I purchased this '01 TJ 4.0L as a DD project and that while the gear lube was very dark there was very little in the way of metallic whiskers.
It all depends upon how long its been since the gear lube was last replaced and how much metallic material has accumulated in a what amount of mileage.
I don't know about 400K, but 200K is completely normal.And I know someone will claim 400,000 miles on original clutch, downshifting every time. And that's great.
Downshifting is hell on a clutch too.
THANK YOU! The "American automatic transmission driving technique" is complete crap. It trashes brakes and is very unsafe. I was going down the east side of Tioga pass with a fifth wheel trailer. I had it geared down and was barely touching the brakes. Even though I'd pull over at every opportunity, the flatlander city slickers would blow past me all pissed off. WITHOUT EXCEPTION, I'd pass them again with their head under their truck or trailer - one guy barely got it stopped before going over the cliff.Sorry but this is complete BS if you know how to properly drive a manual transmission vehicle. Aside from starting off from a dead stop (forward or reverse), unless you really have no idea what you're doing, there is almost no clutch slippage or wear when shifting gears up or down. I've been driving manual transmissions continually for 50 years and have only ever had to replace 1 clutch. That was on an '82 Honda Accord. And the friction disk was not really worn. It was a mechanical failure in the pressure plate.
I downshift A LOT. Not using your transmission to control your downhill speed is a good way to trash your brakes in short order if you negotiate any amount of steep terrain.
Ever smell something burning while following someone riding the brakes on a long, steep downhill? Too much of that and the brakes stop working: brake fade.
Pause for every shift helps. Don't use the drivetrain as a brake. Use the brakes. Downshifting is hell on a clutch too. And I know someone will claim 400,000 miles on original clutch, downshifting every time. And that's great. But it causes the pressure plate disc material to grab backwards a bit as it engages. And that prevents or at least slows the break-in of the material. Using the brakes to slow and stop uses up the pads. They are much cheaper, and vastly easier to replace. And made for the job.
—- Sermon is now over. —-
Yes, normal for the whiskers. I replaced my NV3550 fluid after 20,000 miles and wiped away the shavings. You don't want metal chunks. I have the same issue with having to pause during the 1-2 shift when the transmission is cold. Normal for the NV3550.
Did you use Redline MTL? How much did you end up needing? I am getting ready to do first trans fluid change on my recently acquired '03. Second gear has a bit of an attitude.2004 Jeep TJ with NV3500 5 speed manual trans.. I changed my transmission fluid recently and found metallic whiskers attached to the magnetic drain plug. I know this is normal but is there any way to gauge if the amount is too much or about average?
I just changed mine. 2003 five speed. I bought 2 x 1 quart jugs of red line MTL. I let it fully drain for quite a while.Did you use Redline MTL? How much did you end up needing? I am getting ready to do first trans fluid change on my recently acquired '03. Second gear has a bit of an attitude.
