precise force applied when measuring. (not a C clamp!
I could use a good recommendation on a backlash dial too.Also you will need something like this to check backlash
Edit............Not a recommendation of this particular product
https://www.summitracing.com/parts/...XujO7OT4YeoTz14b7sPGU_ftwqBSC5MBoCTlEQAvD_BwE
If you can wait until January.....I would like to learn about regearing. I hold a degree from the YTI (YouTube Technical Institute) and We did shim the pinion on my sons dana 60 successfully but didn't have to do anything else.I’d have to borrow calipers that nice. Wanna learn to re-gear?
MAybe we were classmates, but it was YTTI, remember?If you can wait until January.....I would like to learn about regearing. I hold a degree from the YTI (YouTube Technical Institute) and We did shim the pinion on my sons dana 60 successfully but didn't have to do anything else.
I’m also going to have to fab up one of those pinion yoke wrench’s, unless you know an easier way. I’m Not spending $30 on that!I borrowed one from the machinist at the base. Someone should know a good brand
I used a big pipe wrench. With aluminum inside the jaws to keep it from biting the yoke.I’m also going to have to fab up one of those pinion yoke wrench’s, unless you know an easier way. I’m Not spending $30 on that!
I saw one of those. They look very ideal for the job. I’ll send him a design like that and be done with it. Reminds me of that staff in Indiana Jones when they were looking for the location of the ark of the covenant (except the staff was removable)I use one like this. At work i do them on a lift so i put a 8' piece of exhaust pipe on the handle and the floor keeps it from turning. A short pipe would do the same if your working on your back. He probably could make one easily for you.
Different brand, I use RCBS, but I use my reloading calipers too.I used the set i have for reloading
https://www.midwayusa.com/product/297498/national-metallic-digital-caliper-6-stainless-steel
