Hello Folks,
I took the 05 LJ out today and got some mild DW at 45-50 today for the first time. Spent some time with a crowbar on the front suspension to see where I could have issue.
Swaybar Links are tight and do not flex under crowbar. No dry rot I can see.
Balljoints seem solid no lateral movement jacked up on stands.
Trackbar is tight some light deflection on axle end. Castlenut is present and pin likely from factory.
Control Arm bushings are pretty worn I can see cracks and get some deflection with the crowbar.
Tires are year old 33x10.5 BFG, will take for a free rebalance maybe 2k miles on em
Seems like on the right road surface with right conditions get some mild DW 45-50. I was on highway today at 60+ and it was smooth before the DW showed up.
LJ has 53k and is in very good condition. Has a 1" ish lift spring and blistien shocks which appear to be in good order.
I am leaning towards some control arms and replacing axle side CA bushings.
Anything else I should crowbar on or inspect before firing the parts cannon? I can get the most deflection from control arm bushings its almost 20 years old and I can bet they are OEM.
Thanks for the info, I had a TJ back in the day so had some experience swapping out arms/bushings.
