I ask because it sometimes settles back to idle very slowly and I have to tap the gas pedal.
Or is it time to check the idle air control valve?
My '04 4.0 doesn't have one either and I don't think it ever did.
This is my setup, which looks slightly different from yours, mine has the auto tranny cable attachedI'll check my 97 2.5L tomorrow. It is all stock in and around the engine.
I'll take a pic tomorrow and post after work.
Here is my modified setup. Ended up with enough extra springs to hook up a few friends:
Did u ever figure out a fix?my rpms stick, even while in gear. if a depress the clutch the rpms will stay there, or it's like i have cruise control on (toyota crawl control) if i remain in gear. when i tap the gas, it drops back down to normal. I've cleaned my iac and it got better, but not for long, and now it happens A LOT. new iac maybe?
Install a hand throttle kit, they work great while navigating rough terrain."touchy throttle over rough terrain" issue
I did! I honestly can't remember what I did, but I believe I just oiled up that little butterfly springDid u ever figure out a fix?
