Absolutely. If you mix rubber engine mounts with poly tranny mounts, or vis versa, you can get vibes. You either need all rubber, or all poly.There's a difference in vibrations?
Didn't know. Stock Mopar motor and TC mounts are both rubber, right?Absolutely. If you mix rubber engine mounts with poly tranny mounts, or vis versa, you can get vibes. You either need all rubber, or all poly.
That’s correct.Didn't know. Stock Mopar motor and TC mounts are both rubber, right?
The red dirt from Moab never seems to go away completely
I like mine , I feel a little connection to the running engine. I have the lopro mount with M.O.R.E. bomb proof mounts. I get no rattling what so ever.It's all rubber. I think the pad is a little thin. But it's not like it rattles or anything. It's just not 4 inches thick.
https://undercoverfab.com/body-and-power-train-mounting/20-ucf-lopro-03-06-tj-lj-trans-mount-.html
It works good for me. But i can feel my knobby tires when I roll to a stop and don't mind. I noticed a new rattle in the dash by my left speaker after install. It goes away when I push on it so I know I can get rid of that.
Good info for my future trail rides. Have the hand throttle installed, running 35s and 5.13 with 6spd. Gonna be trial and error and should be a hoot.I put a throttle control cable on and I set it between 1500-2000 rpm in first gear 4lo while aproa hing something and it walks up everything without touching the gas or clutch. Well i goose it a little sometimes with my foot.
