Thanks! I've seen those and checked those sites too. I like 'em....but not to the tune of +$600! Actually found a set of the 'non-enhanced' version (the much more common, black diamond plate w/o the additional rail) in great shape on CL last week. Picked them up for $60. Not the prized 'enhanced' version, but a solid find.Another member here pointed me to a few places that still have them in stock:
https://www.justforjeeps.com/rockrails.html
https://www.morris4x4center.com/rock-rail-w-rub-bar-satin-black-82209218.html
Pricey at $661 though!
That's a good find. I would also like a set of the "enhanced" rails with the step but you're right, not for $600!Thanks! I've seen those and checked those sites too. I like 'em....but not to the tune of +$600! Actually found a set of the 'non-enhanced' version (the much more common, black diamond plate w/o the additional rail) in great shape on CL last week. Picked them up for $60. Not the prized 'enhanced' version, but a solid find.
The PO actually designed steps that bolt up under the jeep in conjunction with the rock rails and attach/detach with a pin. Pretty solid steel and well-designed, though I doubt I'll ever use them.That's a good find. I would also like a set of the "enhanced" rails with the step but you're right, not for $600!
Hey, thanks for passing that along! I hadn't seen that one and looks like it's the least expensive of any so far, although still pretty spendy. I'll be installing the 'unenhanced' set I found while keeping an eye out for any of these that may pop up at a more reasonable price. Again, thanks for sharing this.https://www.tucsonmoparparts.com/oem-parts/mopar-guard-kit-bodyside-82209218
Just under $500 here. I think that was the cheapest I found while looking.
I've been told that they mount identically, so hopefully that is the case if either of us come across the fancy set.Hey, thanks for passing that along! I hadn't seen that one and looks like it's the least expensive of any so far, although still pretty spendy. I'll be installing the 'unenhanced' set I found while keeping an eye out for any of these that may pop up at a more reasonable price. Again, thanks for sharing this.
