I nearly forgot to mention here that I read an announcement a few weeks ago that Mopar released an improved version of the 42RLE transmission pan for the 2006 model year TJ. It holds more ATF for slightly better cooling and it makes it far more difficult for the transmission to suck air on an extremely steep climb. It of course can be installed on earlier TJs that have the 42RLE which started with the 2003 TJ with the 4.0L engine
So if you're in the market for a new pan for your 42RLE automatic transmission or just want the slightly increased capacity, the Jeep dealer can get it for you.
The part numbers is 52852912AC and you can get it on Amazon here:
https://www.amazon.com/dp/B00G0OUIPM/?tag=wranglerorg-20
Unlike the only aftermarket pan for the 42RLE I'm aware of from RockKrawler, the Mopar pan should fit with pretty much any aftermarket skidplate or bellyup skidplate.
