One small step for @MountaineerTom, one giant leap for the Jeep!
Lots of great parts going on soon. Cool!
Seem to have missed this haul of parts before. Are you just changing out two control arms?Black Friday sale stuff has all arrived, plus a couple things from @ManWithJeep . Body Lift and MML also, bit not pictured. As always, now I just need some time to install everything.
View attachment 296066View attachment 296065
Fortunately the LJ is more forgiving!After I install the raised skid plate, if I have vibes, I'll install the upper rear control arms to hopefully fix that. If it doesn't, then I guess the SYE and a driveshaft will go in.
I bought the control arms and SYE unused from a member here at a good price. There will likely be more control arms in the future.
Looking good man... You're definitely moving on to the next level. Enjoy!!!Torq Locker installed.
Spin test good.
Test drive good.
This was really easy to do. The hardest part was popping the carrier out. Refilled with the recommended conventional 85W-140 gear oil in Valvoline flavor.
Also installed the M.O.R.E. steering shaft riser bracket to go with the body lift and a Rugged Ridge Dana 30 skid. Finished up the motor mount lift with the correct size M10 bolts.
View attachment 299453View attachment 299454View attachment 299455
View attachment 299456View attachment 299457View attachment 299458
Thank you.Looking good man... You're definitely moving on to the next level. Enjoy!!!
I really like your build, in particular because you take such a considered approach.Torq Locker installed.
Spin test good.
Test drive good.
I drove the Jeep to test the locker before installing the M.O.R.E. bracket and it seemed to be fine. I didn’t like how the shaft coming out of the firewall looked (like it was resting on the bottom of the opening), so I went ahead and installed it since I had it. Slightly hard to get your hands in that area.I really like your build, in particular because you take such a considered approach.
I had not really thought about changing just the rear upper control arms if I get vibrations, not sure why, but I hadn't. Maybe now I will think about it a bit more.
I also have that steering shaft bracket as I bought the MORE 1" body lift, but I must be honest I have never fitted it, your post has reminded me of this
Really enjoying the build so far. I keep going back and forth with the idea of a torq locker of selectable locker in the front. I'm looking forward to your results of the tummy tuck. I have everything I need to start mine except for time...
Raising the rubber splash shield in the fender well to gain access that way help a lot with the two larger bolts. Temporarily removing the bolt on the outside of the frame rail that holds the brake lines and moving them out of the way helps too.
I guess I ought to take a look at mine. Since the savvy lift didn't come with one, I didn't even think about it, and even once I learned of the existence of these brackets I was focused on the function and didn't even think about it rubbing.
Thank you.That torq locker is sweet. Some solid upgrades going on! Very nice
Hmmm. Interesting video. The PowerTrax Lock Rite is different from the PowerTrax No Slip that I have. Does the Torq ratchet when you turn?Well, I may not be the best person to compare them. This is the first time I’ve ever messed with an auto locker, or any locker actually. Just off the top of my head I know the Torq has less parts to it. Only 2 springs and no pins. The Torq seems beefier to me from the videos I've seen. It also comes with a new cross pin.
@freedom_in_4low has a good video comparing a few different ones due to some troubles he had starting with the Powertrax No-Slip.
