I see a lot of CB and FMRS/GMS mounts listed but does anyone have a source for mounting a VHF/UHF antenna on the drivers side tail light?
73,
W9VD
73,
W9VD
73,
W9VD
A tail light CB antenna mount will work fine for a 6m/UHF antenna and if properly installed with a good solid RF ground it will provide a good ground plane. Caution if using a powder coated mount that the powder coating will have to be removed in two areas to provide an adequate RF ground. One where it is bolted to the tub and two where the coax cable ground attaches to the mount. If you can find an all stainless steel or aluminum tail light mount life will be a lot easier. Powder coated antenna mounts are a PITA to get working well enough to allow a good low SWR.I see a lot of CB and FMRS/GMS mounts listed but does anyone have a source for mounting a VHF/UHF antenna on the drivers side tail light?
73,
W9VD
Left to right: Stock stereo antenna, VHF/UHF Ham antenna, CB antenna, and unity gain GMRS antenna. Leaving the back clear for some type of HF setup.
I have never been fond of the tail light antenna brackets; they are directional and prone to be broken on the trail.
While the directionality issue of a corner mount is theoretically true, it's not a big enough issue with the TJ when the antenna is mounted on a rear corner to worry about. In over 25 years of running CB and ham antennas at my TJ's rear corners any theoretical directionality of them has been a 100% non-issue for me. In other words I've never had to drive my TJ in circles to find the right angle to communicate via. And I have received far more formal antenna education than the average yahoo thank you very much lol.I have never been fond of the tail light antenna brackets; they are directional and prone to be broken on the trail.
When I replaced the OEM third brake light with a LED ring between the tire mount and the rim; I installed a SO239 threaded antenna mount where the original third brake light power wires were routed.
While this setup is not ideal; the mount is protected and is less directional than the corner mounted antenna.
I did not confuse anything. I know full well the requirements of a ground plane, I constructed them even buried the wiring for ground planes for military communications antenna farms back in the late sixties.Jerry, you confused electrical ground with ground plane. Ground plane is what the antenna needs to reflect signal up and out.
I did not confuse anything. I know full well the requirements of a ground plane, I constructed them even buried the wiring for ground planes back in the late sixties.
This picture confuses me.
The top of my tire carrier is not parallel to the ground.
An antennae mounted here (on mine) would lean back against the tire.
Am I missing something?
