I want to ditch the shovel which requires a dual cardan driveshaft. I would like to remove the UCA mounts and rotate them on the axle tubes vs lengthening the upper control arms and possibly have optional holes for geometry changes. There seems to be hit and miss problems with trackbar clearance to the gas tank. Moving the UCA mount should rule that issue out plus work closer to the factory geometry.
I have seen how Jeeps West does it, but w/o optional holes. They do appear to raise the axle end of the UCA though. I will be contacting them soon.
Are there any other options for UCA mounts?
How hard is it to re-use stock spring mounts, upper and lower?
