Hi, I noticed my fog light icon will go on and off on the dashboard when hitting potholes etc and when I wiggle the headlight/turn signal lever, I can get it to toggle on and off (without the fog light switch pulled out) so I know there is something wrong with the switch. I read a lot about people having the problem with fog lights staying on and was due to bad multifunction switch.
I saw some vids on how to replace it, simple enough but noticed some people had to remove the steering wheel to so do while others did not. I have an 04, do you know if the 04 requires removing the steering wheel? from what I am reading it sounds like certain years required removal but cant pin point the actual year.
I think i am fine without having to remove the steering wheel but can anyone confirm?
thx
thx
