Looks to be 2.5-3.5" maybe?
View attachment 29639 I would sand that down and hit it with some paint. Might as well if you do end up getting a new rear. Looks pretty clean from the pics. What's the frame look like?
From what I can see on their website, 4" is the shortest lift they have for a TJ. And it looks like the kit includes the evil dropped pitman arm.
http://www.fabtechmotorsports.com/J...-Jeep-TJ-2004-06-Jeep-LJ-Unlimited-p2254.html
The stock CA's are actually designed to be quite flexy. Just look how flimsy they look.
FYI, consider this interesting idea in place of a bumper, I might do it if I didn’t need to pull a trailer. A rear crossmember that doubles as a bumper and has weldable d-ring attachments. I think very cool and gives awesome clearance on the rear end.The frame is spotless. That is the only area that has some surface rust on it (the area you pointed out). Once I put a new rear bumper on, I'll sand that down and respray it with some paint for sure.
Not sure who makes that rear bumper / tire carrier.
https://www.motobilt.com/jeep-tj-rear-cross-member.html
You can pay me later @Motobilt
Who knows. They developed it for super clearance. It also would not limit the size spare you could run since it would be flush (assuming Exogate or the like). Just a thought, and an interesting product. I ran with just the crossmember one day and thought it looked good. Certainly an advantage with 31’s, bc your ass end will likely hit sooner or laterI'm not sure I can picture it without a rear bumper... Might look odd, no?
The Posion Spyder original version is a bolt on affair and already has d rings on it. Really nice bumper.FYI, consider this interesting idea in place of a bumper, I might do it if I didn’t need to pull a trailer. A rear crossmember that doubles as a bumper and has weldable d-ring attachments. I think very cool and gives awesome clearance on the rear end.
I wouldn't go all crazy changing control arms just yet. They might work fine at 2 inches. No sense spending money you don't need to. Measure them up. I can measure my stock ones, and let you know if they are different.Yep, I noticed that as well. Stupid dropped pitman arms. What were these lift manufacturers thinking? So I've got a new stock pitman arm coming this week, and then I guess in order to get rid of this lift I'll need new control arms too, because it's got control arms that are fixed length and not adjustable (grrrrr!). So ultimately if I go with a 2" suspension lift, I'll need either stock control arms or something adjustable like Currie or Savvy. I should probably get some adjustable control arms though that allow for mis-alignment incase of any flexing. Not sure how good the stock arms are at flexing before they break something (like a control arm bracket).
