So, been noticing that the dogs seem uncomfortable and hot in the back, and since I inherited the jeep with no rear seat, decided it was ok to take out the buckles now. Picked up a Torx socket set at Tractor Supply ($6 by the way, so super cheap) and took it out.
Step 2: I decided to lay down a thick piece of Styrene insulation down to act as kind of a barrier against the heat that likely emanates up from the tub:
Step 3: Laid the factory carpet back down, noticed that the components on the side are also about the same height as the Styrene
Step 4: So, I found a carpet scrap and laid it down on top of everything. So, now even if we go to the lake and wet dogs get up in here, it's all good:
