myers3512
Did the Luk kit on my 97 recently. All because the spring clip on the fork for the throwout bearing finally gave out.
Have you removed the slave from the bellhousing and checked the position and movement/tension on the fork? Is the spring clip properly seated and the fork moving like it should? I was not thrilled that I had to drop the transmission and replace the clutch on mine for a freaking $1.49 spring.
Otherwise like others have said time to pull it all apart and reinstall.
