My quest for a 32RH pan drain that doesn't break the bank
How hot is your transmission running?? I'm assuming your engine runs around 210, if my transmission spends any time in that range then I'm very concerned, considering it normally peaks around 165 after adding the cooler. Maybe your setup breeds higher trans temps?
I have seen 270 with an actual gauge in the pan, but 230 is normal. They actually run hot
Reactions: MountaineerTom
My Summit pan arrived today. The picture clearly shows a pan gasket, but mine did not come with one. What is the consensus, cork or rubber?
