The problems: light stock tire carrier with a heavy ass spare & difficulty getting it on.
Up until now what I do is lift the tire & balance the very edge on the bumper then try to weasel it onto the studs, then hold it with one arm & one knee while I fish a lug nut out of my pocket & try to thread it on there to take the weight off of me before the whole thing comes crashing down on me (ask me how I know), & I’m a scrawny little fuck at 137lbs soaking wet & getting older & scrawnier by the minute. Seriously I don’t know how people deal with 35s, 37s & up on the trail…
Once I get it on just enough of the tire sits on the bumper to take a lot of the weight off of the carrier & it also holds it perfectly still so there’s no bouncing or movement. But, to open the gate it releases the tension between the tire & the bumper so I have to re-do it. This isn't too bad because I can go a long time without opening the gate, the only thing in back is my tool box & that opens to the front by design.
So far it’s worked for almost 2 years, my gate & hinges are solid & the carrier itself is showing no signs of fatigue, I never see or hear any rattling around even on really bumpy trails; nevertheless this method is getting old due to the difficulties I'm having putting the tire on there.
The fix: certainly a new bumper with swing out carrier is the best way to go but until that happens I needed a way to help me get the tire on & also take all of the weight off the carrier while it’s on.
I looked at high-low trailer hitches thinking I’d flip it up & rest the tire on there but I couldn’t find one the size I needed plus for some reason my trailer hitch is not centered under the tire but a ways off to the left. I’ve seen some photos online where others have finagled things to take the weight off the carrier itself & transfer it onto the stock bumper, but I don’t know how to weld & don’t have the equipment so I wandered around Home Depot for about 30 minutes awaiting inspiration & came away with nuts, bolts, & two 12 gauge right angle connectors, an off the shelf fix that didn’t require any kind of fabrication, just drilled 4 holes & bolted them on.
Total cost: $11.21
First I screwed the connectors to a 1x6 to be sure they were flush with the bumper & to hold it all still while I drilled:
Then bolted them on to test:
Had to bend them down a bit, didn’t calculate in the arcing contour of the tire so when the connectors were at a 90 degree angle the wheel was too high to get onto the studs
Popped the tire on & rested it on the carrier, slid easily back & forth on the studs so they’re not carrying much of the weight at all, really their purpose now is to keep it all tightly bound together to avoid any kind of movement:
With everything fitting together I pulled it all off to paint & while that was drying it was Miller Time, this time not in frustration like last week but in celebration for an idea actually going to plan:
roasted some peppers too, because shit son they’re good on everything
All done:
Can barely see it with the spare on
I've got to say this solved my problem, it made it so much easier for me to get my spare on, it's like putting the tire on a shelf & once it's on there I can hold it in place with one finger while I screw the lug nuts on, the old way was more like trying to balance the tire on the edge of an ice cube.
By the way I was able to do this yesterday in lieu of my cancelled trip off road, there was a big event going on at Rausch Creek & the forecast was for rain all day, again, and I just wasn’t in the mood to be drenched & covered in mud for 12 hours, we’ll gettem next time
Happy Sunday to all
Total cost: $11.21
All done:
Happy Sunday to all
