Rhonda, my love, won’t start.
She’s a 2002 manual 4.0
She’s been horribly neglected the last few years due to reasons and I’m trying to make up for that now.
Full story with all possibly relevant details:
Busted brake line and had to leave her where she was. Got towed. Mechanic at the yard she was towed to fixed the brake line but said he was having trouble starting her sometimes. When he adjusted the steering wheel height she would start. When I went to pick her up she started fine. The following weeks she sometimes started sometimes wouldn’t. At first adjusting the steering column would help, then it didn’t. Tapping on starter relays worked sometimes then didn’t. Then she got left in a public parking garage out of the elements for almost 2 years. Just got her home a few days ago. Changed the oil, transmission fluid, new battery, fresh gas, now to work on the starting issue.
Turn the key to on and the dash lights up, beeps and all that, lights work, wipers only work in ACC position, not in RUN posotion. Turn the key to start and there is a single click coming from behind the glove box, the fuse panel I think. Definitely not from the relays in the engine bay, definitely not from the starter. Occasionally, when the key is turned to start position the dash lights will go off for a few seconds before coming back on.
The check engine light is also on but when I try to retrieve codes it just says “done.” I really don’t want to have to take her to a shop, and would appreciate any input you’re willing to give.
Thanks guys,
Frank and Rhonda
Thanks guys,
Frank and Rhonda
