It seems that what happens is that the PO or someone was mixing different coolants that can create casting sand(sediment) and turn your coolant into a jell-like substance. I read about it on the JK forum, caused when the manufacturer changed coolant specifications, and the dealership repair just started adding the new cooI to the old coolant, but they weren't compatible and a different color. There is like a 18 page thread about it on the JK forum. I believe the sediment is some sort of a precipitation. I had a mechanic do that to me. He did some work on my Jeep that caused him to remove my coolant and he just added whatever he had on hand to refill it. I noticed in less than a week, my reservoir had about an inch of casting sand(sediment) in it. I was furious as I had asked him not to mix the coolants. He said it didn't matter, then I asked him, then where did that casting sand come from in the bottom of reservoir? He said he would flush it, if I got the coolant. I got the coolant, it's the green stuff for my year, and I haven't had a problem since. Luckily, I had noticed it in less than a week after he did the work. If that junk stays in the system, it can clog up and ruin everything, including the engine. Most of the time, the problem is discovered before it ruins your engine, but after it ruins either the radiator or the heater core, or both. I would change your thermostat too. It seems that it has already ruined your heater core, but hopefully you can save the radiator. Just make sure not to mix coolant colors, and keep an eye out for sediment in your coolant recovery reservior. You definitely want to flush out all the sediment. It seems that it tends to want to cake. I saw some caked around someones radiator cap in this forum, and it looked horrible, just like caked sand. If you see water, it should be clear. If not, then it is coolant. Coolant is much more slippery than water and a different color. Coolant will slide through you fingers like WD-40. Water is more abrasive and can cut through rock. So, if you rub coolant and water between your fingers you should easily be able to tell the difference. If you see water rushing out of a hose near your firewall, that might be the hose going to your heater core and it might be coolant. While driving some of it might be splashing on your engine and this might be what you are smelling. It seems you potential have a lot of problems with your cooling system. Unless you are a good mechanic, it might be best to take it for a car repair mechanic, especially if you suspect it is your heater core. Hopefully, it is just a hose.GL.
