So i took out the u-joint closest to the rear axle, it WAS bad the one next to the transmission was still good (original u-joints on shaft)
now im still getting a wicked shake for the first 2 miles
THEN it goes to a regular road tire 33x1050 "BFG/AT" vibe ?
light vibes in steering wheel,shifter and gas pedal
there was ZERO slop/movement in the transfer case before i removed the shaft from that end and used the unhooked axle end to try and move the shaft on the transmission end
somethings COLD and vibrating---then warming up---and loosing the wicked cold shake
could it be my Tires? I do know i have a slight crab on my rear end according to my alignment guy, he said it wasnt out very much butdidnt have any more adjustment
to get it all out (part of the reason im going back down to a 2inch lift from the 4inch
what do i inspect and look for next?
what do you want pics of?
thank you all
thank you all
