I have bought a Dana 44 axle, that came from another TJ. It has all the perches for TJ, but have also some additional components, that i am unable to identify.
It looks like at a distance of 3-4 inches from the end of the differential housing itself, it has some additional perches. On each side of the axle, it has additional welded bracket for something that i dont understand. One perch is large with big hole, and second perch looks like it is 2 nuts soldered inside, similar to what you put for leaf suspension. However, the angles at which these perches are located (also the fact that they are too close for the center of the axle) makes it completely useless for suspension purposes.
The axle is WSM > to < WSM (Wheel Surface Mount) of ~60.5. Bolt pattern is TJ pattern.
Can you guys help identifying what is this axle and what are these additional perches?
