I took some time today and finished up the axle repair. First I wanted to try and address the clearance issue on the ram. As I said earlier, it was just kissing the guard, and not deflecting at all - but I still wanted to take a shot at fixing it without pulling the whole guard off. I only needed it to move an 1/8" to a 1/4".
My first idea was to pull it back into line with heat, so I threw several fat, ugly, hot welds on the undersides of the mounts.
It did move a bit, but not enough. On to plan B. I took an 8' piece of tubing and tried to bend it - but even with all that leverage (and me jumping on the end of the tube) it would not move. On to plan C.
So I went all medieval on it's a$$ (Credit to Marsalis Walls). I took a cutoff wheel to the brace and cut it about 3/4 of the way through from the top.
Then using the 8' tube - but still having to jump on it - I was able to get it to drop down enough. I jambed a small metal wedge into the top of the slit as I jumped on it to keep it in place for welding. The wedge was to help keep the heat from the weld from pulling it back out of place. It worked, but man what a lot of effort.
After that, it was quick work to weld up the cross piece.
Then a little work with the flap disc to clean up the cross piece and remove the failed nasty fat welds on the braces. And after a little paint, it all went back together.
Hard to tell from the picture, but the ram now clears the guard by about an 1/8". In retrospect, a crazy amount of work to take care of something that probably did not need fixing - but, a fun little project.
