Why would he want a date for his Jeep?? Oh wait battery tender duh!!!
You'd swipe right for that jeep!
Have you considered a tender for it?
That's my go-to on the Jeep & mower in the winter. I've been stranded too often on a vehicle that sits.'Baby tender' is easy and cheap insurance.
For the last few months, the rig has been a bit, well...slow on the crank. So much so that the last few times I've wheeled I've been reluctant to shut the rig off on the trail. It has not left me stranded, but there have been a few times I thought it might not start. The charging system seems to be working fine.
I run an Odyssey Extreme, which has been great until now. I installed this one in March, 2000 - so it's only been in there a bit over 3 1/2 years. Since this thing is generally considered one of the best, I didn't know what else to do other than pick up a new one.
The rig is not a daily driver and does sometimes wind up sitting for long periods of time. I do usually drive it a couple of times a week, but always very short trips. Some of you know that I used to run Optima's, but along with everyone else after the Johnson Controls purchase I was only getting a year or two out of a battery - and the reason I switched to the Odyssey.
Perhaps my use pattern is causing the short battery life issue? Anyone have any insight?
Anyway, $400 clams later, it's on the bench:
My battery tray is designed for an Optima sized battery, and since the standard 34 is just a bit larger, it's not a direct drop in.
Easy to get it to fit, though. These ribs just need to be trimmed on both sides - as I did on the original:
So after just a few minutes with a chisel and mallet...
...it drops right in.
Except for the new product number, it looks exactly like the old one...
But the rig is now back to a very fast crank. Hopefully that remains the case and I can stop worrying about it for a while...![]()
Mine dies fast too. Sit in the garage a lot. I try to remember to start it once in a while but I forget. Need to buy a tender. Running Costco interstate now.
I run tenders on my bikes, and I’ve always thought the purpose was just to make sure the vehicle would start the next time. Does running a tender extend the life of an AGM?
You pedobatterytenderphile![]()
My understanding is that yes it does. For me I know one of the bad things for an AGM battery is to become so discharged that it freezes when it's cold outside. Since my Jeep will spend some of it's time parked outside I don't want this to happen.
The tenders aren't that expensive so I guess you could look at it as an experiment and see how long this new battery will last compared to your old one.
Yes they do help extend the battery life, considerably! Even the cheap Harbour Freight plug in solar panels work just fine. The '86 Wagoneer we use as a back country vehicle for the mail route has dual Optimas, with a little solar maintainer wired directly to the batteries. Both batteries were bought in like 2012, 2013 and work like the day they were installed. They get tortured by a hydraulic motor for a 7' snow plow and the Jeep sits 8 to 9 months out of the year.
This is what we have sitting inside the windshield on the dash.
https://www.harborfreight.com/15-watt-solar-battery-maintainer-64251.html
Since wheelin' at Hawk Pride a few weeks ago the rig has been stuck in 4L due to breaking the transfer case front axle shifter cable. On the Atlas, if the front end is in Low (where it was stuck) you can't shift the rear into High (Ahhh, thank you Captain Obvious).
I do have a spare shifter cable (used), but I've also ordered two new cables from Advance. I figure while I'm under there I may as well replace them both.
So, off with the skid:
With the skid off I was able to get up there and shift the front end into neutral - now I can drive the thing while waiting for the new cables.
Since straightening and reinforcing the engine skid a few weeks ago, I have to muscle the front of the engine skip up to meet the mount when installing or removing. Since the guns aren't what they use to be, I took the opportunity to bend the skid up an inch to make it easier to install. Now when I lift it into place, everything lines up. No guns required.
And no, I was not injured or killed during the operation of the high lift....![]()
I may be too lazy to plug the thing in after every drive. I generally expect about 5 years out of a battery (in all my vehicles), so I‘m only off by a year and a half.
I need to build a gigantic wireless charging pad like I have for my iPhone. Just drive the Jeep on and it charges!
Note to self: Develop and insert “Zorba Rolling His Eyes Emoji” here…
