I mentioned that at one point on Saturday the rig overheated - always seems to happen when wheelin' with Victor
. It turned out that the e-fan wire harness came loose, contacted the serpentine belt, which then cut the 10 gauge power wire - but none of the other 3 wires in the harness, strangely enough - necessitating a quick trail repair.
Here are Victor and Brian saying, "Will you hurry up already??? Man, we hate wheelin' with newbies..."
So today I turned that trail repair into a permanent repair. I did not have any 10 gauge wire with me on the trail, only 14 gauge, so I doubled it up to make it work which was fine for the rest of the day.
I cut the repair out, and replaced it with some actual 10 gauge and a couple of shrink crimps.
On inspection, I found the original cause. The retention clip on the fan which holds the wire harness in place (and away from the belt...
) had cracked, allowing the harness to come loose. Damn cheap-ass Spal fan...
So I added a few zip ties to keep that from happening again:
Back in, tested, and done:
Note to self: Carry some heavier gauge wire, Newbie!
