Hello to anyone reading. I am new to jeeps and the jeep world.
I recently acquired a 2005 jeep wrangler rubicon with 98k miles.
It has a hard 1st to 2nd shift and wont go past 2nd. After doing some research everything pointed to a failing PCM. I replaced the unit and it is still having the same issue. Where and what else could it be? Could it be the shift solenoid pack or Transmission oil? I checked the ATF in park and it seemed to be at a sufficient level and the color is Ok. I attached a picture of the ATF color. If someone can point me to another thread or forum I would greatly appreciate it. Thank you
Things repalced:
PCM/TCM with a Wranglerfix unit.
Transmission RPM input and output sensors.
Things repalced:
