I have a 97 TJ with the 4.0 and I am having an issue with a rough idle and a misfire type of jerking when driving. This problem however is intermittent. Here’s my story and what I’ve done.
Had the heater core and a/c evaporator replaced by a mechanic. The next day the Jeep died and would crank but not fire up. Jeep was towed home and the next day it started with no issues. I have replaced the following items so far
Plugs
Plug wires
Distributor cap
Ignition coil
TPS sensor (NTK)
Upstream o2 (NTK)
Cleaned the throttle body
Crankshaft Position sensor
My son just got home and said it did it all the way home, however I could not get it to duplicate the issue. I checked for vacuum leaks as best I could. Is there something that could have happened while replacing the heater core?? Or just coincidence.
Plugs
Plug wires
Distributor cap
Ignition coil
TPS sensor (NTK)
Upstream o2 (NTK)
