Need LED light and 04 Rubicon intro thread
For perspective here is the same place June of 21 when we went.
Reactions: Hog
Started my semi tuck- gained 1.5” , the LO PRO mount helps, but I’m tearing back into it- I think it needs some minor fine tuning and it won’t buzz at idle. It is tight.
Here are the lights that got this started.
John Cooper asked how I was getting power to them.
Wires John. I’m using wires.
I likes my mount solution/ the rack its’ self had a place. All this gets coated/painted.
Reactions: John Cooper
Cleaned the cowl- small miracle we don’t get sick from the air that travels through this-
  • USA Proud
Lights wired on the rack- tomorrow evening is the switch and relay. Wires hid pretty good.
The only good route for power I see is up the passenger side post via cowl.
Any other ideas ?
Setting up a cross bar to run lights so that when I pull the rack the A Pillar legs have a purpose -
This gets vinegar washed, painted black and 4-6 lights, same plug will fit these-
The angles ends match the racks’ A Pillar angle.
dang man how do you come up with these great ideas ? you are such a genius, I would never even think to add DISCO light to a DUCK POND ! man you will be the envy of EVERY jeep owner ! I can just see you know lining that roof rack with clear plastic and filling it up with water and sitting in downtown Huntsville in the evening. getting out emptying your purse of duck into the pond and turning on the DISCO lights, You'll make the front page of the paper for sure....
Reactions: tr21triton
