Need Longer Parking Brake Cables
Sfoote
Silverton, Oregon
Long story short, had a 200l TJ with G2 Front axle, ARB. Black Magic brakes, & 4:56 gears, rear is a Dana 44 LS, chromoly axles, 4:56 gears & drum brakes running 35's. Also had BDS upper & lower control arms, shout out to them as they warrranted the damaged ones. Had built this Jeep over 7 years from stock. Last year it was totaled by an impaired driver. Drive train survived & in the process of swapping over to a 2005 LJ that has Dana 30 front, Dana 44 back with 3:73 gears. Trying to keep the money on this swap to a minimum & am totaly fine with rear drums, just that the parking brake cables are too short.
I use these Willwood universal cables from Summit:
https://www.summitracing.com/parts/wil-330-9371
Cut them to the length you need - worked fine for me.
