Need rear brake part
double_e
ct
My new rear axel snapped and rear drum slid off
Now it’s almost together but can’t find
tj Emergency Brake Lever Bar or called
Parking break bar, Parking Brake Bar Lever or 10 Other names does not come in a rebuild kit
Can not find in stock
hear
Prosper, TX
Time to to a disc brake swap I guess!
If that bar doesn’t come in the overhaul kit, then you may have to search other vehicles that use the same setup. What vehicles those are, I have no idea. Somebody here will know.
03coloradowrangler
MI
dorman 21158. my local oreillys & auto zone HUB location a few towns away shows it in stock
hardtailpan
Northeast USA
Usually called a "brake equalizer bar" it's only needed for the emergency brake, but yes, "help/dorman" sells these, at least for GM, not sure about jeep.
double_e
double_e
ct
Finding for gm looking can’t find here
If not installed while waiting u can still drive just no emergency brake correct
Reactions: hardtailpan
hardtailpan
Northeast USA
Yes, just the ebrake in that wheel won't work, also a spring usually goes over one end of this bar, I think it's primarily to keep it from rattling.
double_e
double_e
ct
I did end up ordering it from O’Reilly’s auto parts to get today nobody had it
But 45 min away
thanks for giving me the part number nobody knew
