Where is elephant hill? The only one I know is Canyonlands.My steering linkage broke on elephant hill going down. I broke the number one rule. I came alone.
I need some help.
What broke, maybe we can MacGyver it.
I thought about removing the broken piece but there’s no way it will be able to thread again. I decided to leave my jeep here for the night. I hope nothing happens to it. I’m with my girlfriend the jeep is pointing downhill and it’s just not safe. Hopefully someone can help me tomorrow.Ouch. Thinking out loud here. Could you separate the tie rod and the drag link, remove the broke bit, thread the end into the nut (making it none adjustable), and reattach the tie rod/drag link?
Glad you guys got out ok.I thought about removing the broken piece but there’s no way it will be able to thread again. I decided to leave my jeep here for the night. I hope nothing happens to it. I’m with my girlfriend the jeep is pointing downhill and it’s just not safe. Hopefully someone can help me tomorrow.
Thank you.Glad you guys got out ok.
Maybe someone has a spare drag link sitting around.
This group may be able to help https://www.facebook.com/socaloffroadexplorers/
Good luck. Keep us updated.Thank you.
Unfortunately I don’t have a Facebook.
If that is the place off of Mission, I can snag some stock steering and bring it to you. Do you have tools?I thought about removing the broken piece but there’s no way it will be able to thread again. I decided to leave my jeep here for the night. I hope nothing happens to it. I’m with my girlfriend the jeep is pointing downhill and it’s just not safe. Hopefully someone can help me tomorrow.
Luckily for me I have a currie steering. My jeep has Oro offroad steering with a adapter plate on the steering knuckle. Could you tell me if my steering knuckle is drilled out ?If that is the place off of Mission, I can snag some stock steering and bring it to you. Do you have tools?
Jeep is not on stable ground. I was going down hill when I hit a bump and the steering broke. I need to move the wheels get down hill to more level ground for the repair.If the jeep was on stable ground... could it be a field repair?
Or just get it to a road for towing?
Your post got cut off but I think you were asking if the knuckles have been drilled for the bolts. Based on what I see in the instructions, I don't think so. The minor diameter of the taper (small end) is 1/2". I believe he is using 1/2" bolts so you don't have to drill. I also have knuckles if you need them.Luckily for me I have a currie steering. My jeep has Oro offroad steering with a adapter plate on the steering knuckle. Could you tell me if my steering knuckle is drilled out ?
Your steering very likely broke because something is smacking into the draglink when the axle moves up.Jeep is not on stable ground. I was going down hill when I hit a bump and the steering broke. I need to move the wheels get down hill to more level ground for the repair.
Yes I was asking if my knuckles have been drilled. Thanks. I will keep you posted. Going to grab a bite to eat then head over to my jeep.Your post got cut off but I think you were asking if the knuckles have been drilled for the bolts. Based on what I see in the instructions, I don't think so. The minor diameter of the taper (small end) is 1/2". I believe he is using 1/2" bolts so you don't have to drill. I also have knuckles if you need them.
